Visuals beyond limits
Tempest GP27Q
Experience truly immersive HDR performance like never before with the brand-new Tempest GP27Q MiniLED Monitor with 576 local dimming zones. Paired with a Quantum Dot WQHD resolution panel with an extremely fast 165Hz refresh rate, the GP27Q is the perfect next-level upgrade for your setup.
€600.00
A True Work and Play Monitor
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
Deep Black Performance
Quantum Dot Visual Brilliance
Brightest Shine
Smooth Operator
Adaptive Sync is essential for maintaining a smooth experience when playing games. By synchronizing the frames outputted from your GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
Easy On The Eyes
Cutting Edge Speed
Stunning Clarity
Connection Master
Make It Your Game
Cooler Master Unique Design
Master Agility
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
AMPLE Connectivity
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
