More Balance, More Burst
Mobius 120
Cooler Master is introducing the Mobius Series representing the performance line of fans with a new entry – Mobius 120.
€24.99
PERFECTING ENGINEERING
Cooler Master’s Mobius 120 is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor
45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
VARIOUS SPEEDS, VARIOUS FUNCTIONS
The Mobius Series offer various speeds for distinct usages. With the Mobius 120 operating up to 2050rpm, it is perfect for your case and chassis air intake. The Mobius 120P ARGB spins up to 2400rpm, designed to handle performance for air and liquid cooling.
